2 sided material c4d front back materail tag vs layered material normal map mask
is there for any technical or artistic reason a solid argument for using the layered material approach with the normal map effect in the mask channel VS using 2 normal materials and apply them to front back via material tag?
thx for any info what is the better way to achieve a good two sided material :smiley:
best, bs
I guess it comes down to work flow and ease of use. For me personally, I tend to use the layered material approach.
https://help.c4d.corona-renderer.com/support/solutions/articles/12000044906-how-to-create-a-2-sided-layered-material-with-corona-renderer-in-cinema-4d
ok, so technically speaking it makes no difference?
Dead link above… goes here: https://support.chaos.com/hc/en-us/articles/4528506793361-How-to-create-a-2-sided-layered-material-C4D
It’d be nice to consider this as feature request, since it appears to be native to Corona in Max (e.g. [“Easy double sided decals…”](https://forum.corona-renderer.com/ Easy double sided decals... #msg225976))
:wink:
