2 Sided Material / Transparent Material not working on Vantage
Hello, I am trying to create a transparent material for curtains in Vantage. I created a 2 sided material in Vray which works in Vray but not in Vantage (see below and attached). In Vantage, the the transparent material is a solid colour. I have the ‘Opacity Map’ and Leaf icons checked in Vantage. I have all latest versions of the softwares. Any advice?
SKETCHUP
VRAY
VANTAGE
MATERIAL
Procedural textures (like the Falloff texture in your case) are not supported for the opacity slot in Vantage.
You have to use an image file.
Also semi-opacity is coming in the next Vantage version.
For now there is only clip opacity.
Greetings,
Vladimir Nedev
Hello Vladimir, thank you for your clarification, much appreciated.
