Hello guys,
sorry if I still break the boxes, but I have just seen in the gallery section the possibility of creating materials in the diffuse that have the front and the back, very useful in the leaves. unfortunately it was used in 3d max. For cinema 4d there is the function? I can not find it.
Not a problem! This is the place for all questions, from “trivial” (but nothing is trivial when you first run into it!) to “so complex it makes your head spin trying to follow what they are talking about”, and all levels of questions are welcome!
doesnt simply enabling translucency do the job? (2-sided in vray sense of light is coming through)
to map a material to the front/back simply using front/back in the texture tag seems to work…
what does the layered material / normal dir setup do?
