Hey there my name is Matt Rittman and I have a bug to report. When using two HDRI’s… one for a background and the other for lighting, it actually renders the one for lighting, and not the one I have set up to use as the background. Followed this tutorial: https://youtu.be/nVGmEa8tIrQ
Then I misunderstood that. You were talking about two HDRIs and the tutorial also uses different maps as backgrounds. So I assumed Maps. With two maps everything works as intended.
It looks like here’s a conflict.
Meanwhile, you can circumvent it through the scene environment options.
edit: can confirm. If only one material is used on both skies, there’s the problem. If the materials is duplicated and copied to the second sky it works.(see pic)
Glad I could help. Don’t forget the scene environment tab in the crn render settings. It’s just as easy.
Many HDRI packs come with multiple resolution files and you can plug in a small 1024px hdr/exr map for the illumination and higher resolution files as jpgs for the other channels.
That way you get the same result but save a lot of ram.
Hey Eddoron, not sure what’s going on but even when I try using the scene environment tab in the Corona render settings, it doesn’t do anything when I change Offset U.
The environment tab works correctly. Maybe you made a mistake using it. You don’t plug in the sky but the materials. no sky needed.
I just tried it in IR and all channel that I used were responsive and changed their offset/rotation.
Hmmm something is wrong on my end, cuz I did plug in the materials and tried changing the offset, and it does nothing. Maybe the Mac version has the bug?
Well, that’s weird. Could be a Mac issue. I work on Win, so I can’t help there. But maybe it’s something different.
Could you please share a file where that problem occurs?
Yeah it’s gotta be a mac issue, because I just tried adjusting the Offset U on my PC and it works just fine. I just used the scene file from above. Plugged the HDRI into Scene Environment in the Corona Render settings, enabled the Override checkbox, and adjusted the Offset U and it works fine.
Can someone else with a Mac see if they’re having the same problem?
I tested your scene on my mac in Cinema 4D R19.024 with Corona RC4 and it works (in offline renderer and also in IR). I would like to ask you to create screen recording of your problem and to upload it somewhere to be sure I am reproducing your problem in the right way (I simply downloaded your scene, opened it in Cinema and immediately started IR and when I change “Render Settings → Scene environment → Offset U/ Offset V” rotation of HDRI map successfully changes).
Okay I see where the problem is! The problem seems to be only when typing in a specific value and pressing enter. When adjusting the value using the spinner however, it works. I have done a screen recording:
Please let me know if there’s anything else you guys need! Thanks!
Matt
