I’ve a problem with the VFB render region.
The issue is that often , when I start an interactive render to check materials&lights settings, I use the VFB render region and then, when I’m ok, I stop the render leaving the render region icon ON.
Then I start a production render and the renderer uses that region.
Do you think that there should be a way to avoid this?
If it’s just me, well… not a problem, I’ll try to pay more attention on this… but if someone else have feeling it’s a minor annoying problem, please write your experience.
My suggestion is to add the feature to set 2 different area for render region inside the VFB.
Or at least if the area is set when interactive mode is on, that area affect just that mode.
When you start a production render, that area is not used.
What do you think?
