I have to re-render a job I did in 2010 a month ago, but for some reason the file will not open properly now. I was able to merge the contents into a new file in Max 2011, but all the bitmaps are gone. Not just broken paths, but just blank bitmap shaders etc.
Does anyone know some trick/setting that might cause this? I have not had it happen before.
some times ago it happened to me as well
an it was simply opening a max 2010 in max 2010!!!
all bitmaps gone, not only the path was missing but also the bitmap name so all the rebuilding process was a pain
