2013 - LAG After Render
I’m quite sure I read about this before it was released. I think this was one of the “legacy bug fixes” they were touting…
I didn’t have a problem of how it use to work, why would they “fix” what’s n ot broken
it is a VERY SIMPLE FIX. They have the little isolate icon on the UI now. The ONLY thing they need to do do is not let this icon affect the command in the quad menu. Thats it. Then it will be fine.
Meaning:
Quad menu isolate use to be for isolate. Now it is for isolate AND unisolate. So if you’re already in isolate, the quad menu command changes (it has a tick next to it) so then when you use it again it unisolates. Theys should have juyst left it as is, and ADDED the new icon on ui without touching the quad menu command
Makes me wonder how much beta testing goes on nowdays…
this script apparently restores isolate behaviour as per BEFORE 2013
http://www.scriptspot.com/3ds-max/scripts/isolate-selection-legacy-mode-for-2013
We’ve made the jump to Max2013 and are experiencing major viewport-related issues. It is so clunky we can’t quite believe it. We have been on Max2009 since its release, and dropped of the subscription program at that point after we struggled so much to get Max2009 working properly (graphics issues, 64-bit issues etc). It caused us real headaches. To be honest, we use a very small proportion of the Max toolset. We mainly model in Autocad and render with Vray, so Max was a vehicle for bringing it all together. Upgrading every year just seemed pointless to us.
However, max2009 is becoming a bit long in the tooth. Plugins and models were increasingly being developed/created for versions after Max2009, so we were becoming less and less ‘compatible’. We finally decided to get back onto the subscription and bring us inline with the current release, being told that Max2013 was a far more stable and smooth edition than Max2012. Autodesk were adament that 2013 was ‘THE’ release, and that it had been thoroughly beta tested for months, which is why there was a service pack as soon as Max2013 was released.
So far, our experience with 2013 has been very poor. Slow viewport performance. Menus keep disappearing. Sluggishness. Delays. Hangs. Undo still is completely unreliable. It is quite unbelievable. Our systems are decent (i7, 16GB, GTX480 cards, SSD hard disks), but I don’t think we have had such issues as when we upgraded to Max2009.
Very, very disappointed, and furious with autodesk.
2012 wasnt that bad and my 2012 actually runs like a dream. But yes in 2013 I’m getting major viewport slowdows. The issues I’m getting relates to switching between viewports, maximising it, switching between shaded and wireframe takes forever. Tested it on my ATI 6990 (4gb ram) and we also tested it on a GTX 560 that has same issue with viewports. It seems to be related to Nitrous. Direct3D and OpenGL is a bit better, but then you loose the “niceness” that comes with Nitrous, or should I say thats suppose to come with it :slight_smile:
We are having a weird issue at the moment on 2 of our workstations. We are using the material editor and tweeking the diffuse colour. The sample swatch is changing colour, but the preview sphere isn’t updating at all. It also doesn’t update the geometry that the material is applied to when we hit render.
Anyone have this?
Are you using the Slate editor? If so, have you double-clicked on your material sphere befor editing? I only ask because you’re coming from Max 2009 & it can take a little while to get used to the some of the slate editor’s nuances - double clicking being the biggest pain :slight_smile:
As for the viewport performance, are you using Nitrous or DirectX?
Tried with slate editor but it is much to clunky, so we have gone back to ‘classic’.
We have been using Nitrous, but we are now trying DirectX because of all the issues and clunkiness.
