2020 or 2022 Maya Crashed using xGen with VRay 5 - Connect the VRayUserColor to Dye Color from VRay Hair Next
Hello to All !!
I´m testing it with VRay 5 and Maya 2020.4 and Maya 2022. Please check the video:
This video you can see the problem
This works fine if i connect the UserColor to Diffuse Color from VRay Hair Next Mtl but the error coming when I connect it to Dye Color from VRay Hair Next Mtl
- You can use this method while they fix it
You can use this workaround that I have found, You cannot directly connect the UserColor to the Dye Color, you need to do it through the RemapColor node or a similar node
Thanks for posting the workaround, Carols.
The crash is in our backlog
Thanks Alex!!
