27 inch monitor
I tried to save a bit of money and recently purchased an Asus IPS monitor for home use (Asus PA248Q); I wish I would have paid the $80 difference to upgrade to an equivalent Ultrasharp. The Asus works fine, I ended up keeping it, but the Dell’s I have in the office are much nicer to work on. The dark grey to black tones are where the Asus falls short. There is also a slight light leak in the bottom right hand corner of the monitor. I only mention this so others don’t make the same mistake. Stick with the Dell Ultrasharps.
Regards,
Andrew
This might be a rumor, but I’ve been told by several past colleagues that the dell ultrasharp monitors are the same inside guts as the apple cinemas, just a different outer body…but that was around 6 years ago!
