2D Placeholder for 3D Assets. Assets in 3D look great but would be very good to have them already associated to decent 2D elements.
Submitted on AHA Ideas by andrea.matta (ENSCAPE-I-679).
Status: planned
Wenn wir den Design Prozess des Archtekten unterstützen wollen und den Workflow harminosieren wollen, sollten wir auf CAD zeigen, was Architekten brauchen und nutzen können. Neben der 2D und 3D Grafik dins jedoch auch die Meta-Daten an den Objekten sehr wichtig. Erst mit Meta-Daten werden unsere Assets “BIM-fähig”
Submitted on AHA Ideas by n.graeser.
I currently edit all of the archicad GDL placeholders, so yes this would be a great addition the the object library system
Submitted on AHA Ideas by john.
I think this is an important problem to fix, but using 2d representation is not the way to go in my opinion for these reasons:
This solution will create extra work for artists when creating assets because one will need to generate a 2d representation
This is not backwards compatible. One would need to go back and update the existing asset library.
In programs like Revit, a 2d representation would still not be enough, one would need to include a masking region underneath, make sure it only shows up in floor plans, …
It would only work for plan views, not for elevations, non-rendered 3d views etc
Instead I would propose to support smooth edges on the Assets. Revit 2022 does not yet support this, but it has been announced that Revit 2023 will support smooth edges on imported meshes. I have made mockups about how assets would look if this was supported, you can find them here: https://twitter.com/pieterschiette/status/1278390583590113281 I hope you will agree they look a lot better and it wouldn’t have any of the downsides listed above. I’m also relatively confident that, at least on the CAD implementation side, my approach would be a lot easier to implement.
Submitted on AHA Ideas by Pieter Schiettecatte.
Would save a lot of time getting Enscape assets to look correct in plan. Currently we have to manually draw out 2D details inside the asset families if we want to use Enscape assets. Often it can sometimes be quicker to just go with a native revit asset instead, which often don’t look as good in Enscape.
Submitted on AHA Ideas by sam.k.hayward.
Plans in revit
Submitted on AHA Ideas by galar.julian.
i’m a revit user it’s great to have it
Submitted on AHA Ideas by choacchoac.
Would save the need to add in a second element as the 2D placeholder
Submitted on AHA Ideas.
This would remove the need of deleting or hiding the Enscape-objects when you want a clean floorplan. In some cases we even have 2 models. One with the Enscape-objects and one without.
If these 2D-placeholders would also be visible in sectionviews/elevation, that would be a nice to have
Submitted on AHA Ideas by danilo.gavilanes.
Yes, currently we must do a lot of hiding of ugly Meshes in Revit and performance suffers
Submitted on AHA Ideas by mruehr.
this really really useful !!!
Submitted on AHA Ideas by c.
That would be great, this way I can leave the Enscape assets in my Archicad drawings without having to swap them out with Archicad objects.
Submitted on AHA Ideas by peter.
Especially in ArchiCAD, where we strive to have everything with a 2d AND 3d depiction, I would love to be able to keep all my trees (for example) as the 2d… Right now, nothing is usable as a 2d plan view.
Also, strive to make the 2d version DIMENSIONALLY consistent with the actual 3d. Even now, the 3d blobs in ArchiCAD are not accurate enough to reflect what I’ll eventually see in enscape.
SIDEBAR: I have already “HACKED” some of the tree object to accomplish this… It is real easy to do and I’m happy to share my methodology. (of course, this will be specific to ARCHICAD)
very useful for optimisation of workflow
Submitted on AHA Ideas by williamroucherthomassin.
One of the things that stops me from using the asset library is this exact issue. I have updated this on some plants for site plan purposes, but it’s more time consuming for many other things.
Submitted on AHA Ideas by bryan.
We find we end up having to have a duplicate floor plan to hide the enscape assets for rendering, etc. and have our ‘finished’ floor plan saved separately. Like doing work twice - this would cut down on work!
Submitted on AHA Ideas by ktuckey.
Because the B-Rep based assets aren’t useful for 2D CAD.
Submitted on AHA Ideas by a.dengl.
so important
