If you look closely, the surface is open in the 1.09 version as well; it would be best to have a small black boundary around the bitmap you use (unless it is tiled, of course).
thanks Vlado!
you’re right as usual
the holes are present in both versions
i guess something about the lighting is what makes them show up more in 1.47
no biggie
still let me join the army of those crying about the speed
the best a got so far on an exterior to match the quality of 1.09 is a rendering ~70% slower than it used to be
whoever had the idea of per-object QMC settings was really thinking
because certain object such as grass don’t need as much lighting and AA detail as buildings for example
and having a flexibility of per-object quality control could be a big time saver
