I’m doing some comparisons on 2K vs 4K materials to see if it’s ever worthwhile to use the latter, given the higher memory usage and file size for my larger projects. However, in some testing it seems the difference from 2K to 4K in Enscape is negligible, compared to what I see within SketchUp.
DLSS is OFF in Enscape. Also figured it might be Denoiser, but that doesn’t seem to do anything noticeable in this test scenario either. Color is mapped only in the examples attached (no bump, reflections, etc). Hopefully the attached images don’t get compressed too hard and this all shows as I see it here on screen.
what’s the texture scaling in the material? Enscape automatically downscales textures that have a small scale in the scene to avoid unnecessary memory consumption. Thus if you increase the scale in the material the 4k resolution texture should look notebly different from the 2k texture. We support up to 16k resolution for largest scale use-cases, e.g. using satellite images on an environment model.
Obviously I’m still failing to grasp and retain the information, given that’s my original thread ^^ .
What I usually do is set up the material (say, from Poliigin) in SketchUp at the tiling scale they show, which is usually around 3m x 3m (call it 10’ x 10’ for us USA users). If Enscape reduces the resolution of the material, how am I supposed to get a high resolution material to show in a close-up/macro view? Is there a size/scale that Enscape decides at which to downscale the resolution?
I suppose I’m ultimately asking for a button that says “don’t downsize resolution?”
Here’s just some more testing I’m doing. Loaded up D5 to compare the 4k maps vs Enscape. Massive difference. Set aside the FOV/view difference (tough to match), am I doing something wrong here?
Is there some sort of logic I can follow to avoid automatic downscaling of my materials? I’m not sure I understand why Enscape would do that on it’s own, when it’s very simple to replace the material maps with higher/lower resolution files individually as needed. Plenty of memory available.
Here’s another example of a nice Carrara Marble that loses a lot of the vein definition. It’s scaled per the Poliigon guidance (8’-2" x 8’-2") within SketchUp and Enscape, but it being compressed it seems still.
Right now, there’s no option to avoid that. We discussed adding something like a check-box to the material editor like @rifkin suggested, but it wasn’t a priority yet. The reason we do it, was quite frankly, because people are simply not aware how much memory such high resolution textures consume and it’d be a cumbersome manual task to go over potentially hundreds of materials and manually downscale their texture maps. Running out of GPU memory is actually one of the most common issues people are facing with Enscape and texture maps can eat up a significant portion of that.
While the current behavior might not be ideal to do a close-up shot of a textured surface the texture resolution is usually high enough not to be noticeable for any ‘regular’ camera perspective.
For what it’s worth I’m not aware of many complaints in that regard, however we might revisit the parameters for future releases as we see that more people upgrade to newer GPUs with more VRAM.
@Clemens_Musterle :thumbup: I totally get the rational for Enscape to be more designed around “simplicity,” but assigning materials to objects (1k vs 2k vs 4k, etc) is trivial. Surely the Enscape team can see the use case of needing key elements in the models to be higher quality than the rest and needing to be able to control that. A key component of the design that the client is really going to appreciate makes a word of difference, and needs to stand out. For some of the more artistic rendered views it does make a difference. It can be a bit frustrating to not get the desired result only to find out that Enscape is squashing my texture maps quality behind the scenes and there’s nothing to be done about it.
I don’t see the harm in exposing a simple checkbox for a user to toggle on/off if they want to gain more control. Those of us with higher end GPU’s have plenty of memory at our disposal. In my current simple bathroom remodel scene I’m working on, I’m only using roughly 30% VRAM (edit: that’s a realtime preview usage amount - jumps to 95% when rendering ~6k+ image).
If that feature wasn’t enabled you would run other of memory and crash when you did a 6k+ render right?
There was a feature suggestion for performance monitor to be included in enscape - perhaps having the controls available make more sense when a user can see the budget they have to work with.
For every 1 person who constrains their entities and textures, 100 others will immediately break things and cause themselves problems.
I see this daily with even just SketchUp - this weekend I spent hours picking apart a model made by a studio that had 10GB of geometry - it took up 30GB of system memory just to open. Because users have carte blanche access to keep dropping inappropriate amount of data into the file without knowing what the impact of that is.
You see exactly the same thing here - crash reports unveiling that they user has stuffed a model with 4K tiled textures and 16K HDRI images.
Other users planting a literally forest of trees made of 6000individual leaves each and then using 90 spotlight objects.
When you are working with real-time renders you at inherently working within fairly right limits and this drives people to work smarter
Precisely why I would prefer a pinch more granular control in what’s happening. I specifically want to load high res materials for very specific objects.
On a more helpful note - have you tried overriding your texture filtering settings?
I don’t know if it will affect renders, but it may help during preview.
Also - if you are trying to setup a specific shot where the texture is particularly important - scale your whole model x10! You’re more likely to see the full res texture.
I would like to share my utmost support for allowing full texture resolution.
Many of the most evocative compositions use elements in the foreground, mid-ground and background. Discounting one of the three is a real limitation for a render engine. If I recall correctly, Lumion has has this capability for some time and Twinmotion recently introduced it to broaden their market audience with product visualization as well.
So… in sketchup, this does not scale the camera so this is a non-starter production wise for sketchup users. However it should be possible for Enscape to enable a global scale adjustment that also scaled the camera… this has been asked and ignored already.
I could see a nice compromise would be to have enscape by default downscale unless someone specifically noted to not downscale a specific texture. A way to apply this easily might be to put a keyword in the file name like they already do with grass and metal reflections etc or maybe a checklist of some sort that poeople can check and the code would skip that texture.
They’ve already made it very easy to place the appropriate material maps in the material editor, as with every other render engine. They’ve added the unnecessary complexity by choosing to automatically restrict/compress/downsize user-selected material maps in the background, without any documentation suggesting so (at least, I can’t find any mention of it in the wiki pages). I spent way more time that I’d like to admit trying to figure out what what “wrong.”
I don’t see how it’s deemed difficult to simply let a user choose their own appropriate material resolution manually. It’s trivial to replace 4k maps with 2k on the fly, as needed- or to create our own quality versions.
Reading through all this, I am in favor of a solution where we can have an “opt-in” checkbox in the material editor when there’s a specific material I know I need at full resolution. Otherwise everything else remains the default Enscape downscaling. (I’d also like a solution like in V-Ray where you can link a higher res image for rendering while keeping a lower res image within the Sketchup file.)
I’m still against some check is method because it think it’s overly complex vs simply using appropriate maps. But, should that be the compromise, the check box should only be to downscale. Give users the ability to use the material maps they own and require.
The burden of performance should be on the lower end machines to check boxes that lower quality in order to perform the task.
For 95% of users, 95% of the time the current setup is perfectly fine. If you want to make use of full res textures for a particular situation then the ‘burden’ should be on you and not my GPU
So then why do we have a quality slider built-in as well as further performance related options available withing the settings menu? By this logic, the solution is a dead simple checkbox in the settings menu - AUTO-SCALING MATERIAL RESOLUTION: ON/OFF. No different than any of the already available checkboxes:
If a user is choosing to set up a custom material via the editor, I’ll say it again - it’s trivial to use a 1k map in the slots vs 4k (or 2K, etc) if they are concerned about performance. This functionality is already built-into the software and they can just remove the auto-scaling programming. For those that can’t (or don’t want to?), there are plenty of 1k maps available in the built-in material library.
