2sided Mtl - Gradient Ramp as Translucency Channel via MultiSubTex
i found a very strange thing, I can’t explain to myself.
I want to create a fabric material (VRay2SidedMtl) with stripes.
The stripes are generatet with a Gradient Ramp map.
The selection of the color of the stripes should be switchable by Material ID - so different Gradient Ramps are put in a MultiSubTex
The brighter the color of a stripe, the more translucent it should be.
I don’t just want to use “Muliply by front diffuse” because I want to have a little more control over its behavior.
So I built a material like this
→ Image 1
You can see the detour, the stripe maps go, through an Output Map - leading to the translucency channel of the 2SidedMtl.
As long as the Output curve is straight 0-1 everything is fine.
100% white means, 100% of the backside ist visible.. and 0% of the front side.
→ Image 2
Now when I set the Output curve to exaggerated 0-0, the whole map gets black, and therefore there will be no translucency.
100% black means, 0% of the backside is visible.. and 100% of the front side.
This works for the map in Channel ID 1 of the MultiSubTex.
All following Channel IDs ignore this Output change.
This only happens with Gradient Ramps.
When the origin map is a Bitmap or Checker or something else, everything works fine.
→ Image 3
I am not sure if understand the issue correctly. Could you attach the scene here so I can take a look?
It looks like perhaps the VRay2SidedMtl Translucency texture is not evaluating the Material IDs for the MultiSubTex.
Everything seems to work as expected from what I tested. Best @matthias_turbanisch sends the scene in question.
The MatIDs itself do work properly within the translucency channel.
As i wrote: with any other map, than a gradient map, everyything works fine.
I attached the file here in the post. I hope, i make this correctly since I’m not really experienced in this forum
(this is my first topic)
Translucency Bug.zip (68.4 KB)
Thank you for the report. It seems the issue occurs on V-Ray GPU only; the Gradient Ramp has wrong mapping when used in any slot other than 1 in the VRayMultiSubTex. We already have the issue logged (internal bug-tracker id: VGPU-3179) for developer investigation. As a workaround, you may bake the Gradient Ramp maps.
