Hi, im stuck how do i achieve this? double sided material like 2 texures on each side or 2 materials one at each side? vray2sided with translucency black or white doesnt seem the same. ty
Falloff map with Towards / Away type and stepped Mix curve could do the trick - here is a quick example:
I can’t try it right now, but does the standard Double Sided material work with v-Ray?
Thank u !!
