3.20.02 Cant connect slaves after the last render
Hi vlado… need advice.
All the nodes cant connect after finisht the job. The only solution is restart, mannualy, all the spawners.
max 2016
windows 8.1 64 wostation
Slave: windows 7
Try the “restart slaves on render end” option?
hil Vlado!!! :sunglasses:
Yes…
Al the usual settings for DR jobs are enable.
Save Save scene
Restar salve
transfer assets
etc..
All the spawners are from 2016 and 3.20.02. The Previus Spawenrs (2014 and previous) has been deleted.
ive just started having th same problem on one renderbox. one starts again as normal, but the other needs a manual restart. strangely it was working this morning.
Does it happen on every scene?
What happens if you render a relatively simple one with a few basic primitives and a light?
With any scene.
I will try that
i just had a deadline, good timing with this issue.
:(:cry:
Can you also show me the V-Ray log file from one of the render servers once it refuses to render?
[2015/Jan/27|17:33:57] warning: Failed to delete server scene file “C:\Users\monkey\AppData\Local\Autodesk\3dsMax\2014 - 64bit\ENU\temp\vray_server_scene.max” (183)
is the last entry in the log file on my problem machine. a permissions issue? strange its just started happening, ive been using this renderbox for ages with no issue.
do you want the rest of the log? nothing else there looks out of the ordinary to me.
Is it possible that you have two V-Ray spawners running?
nope, i have the service there, but its stopped.
In my case its the same thing.
Console created, V-Ray A from Jan 8 2015, 13:43:24
[2015/Jan/11|01:48:08] Scene loaded from “C:\Users\granja1\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\temp\vray_server_scene.max”
[2015/Jan/11|01:48:08] getting sequence data…
[2015/Jan/11|01:48:08] sequence data is NULL, aborting
[2015/Jan/11|01:48:08] Closing DR session from 192.168.1.200
[2015/Jan/11|01:48:08] warning: Failed to delete server scene file “C:\Users\granja1\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\temp\vray_server_scene.max” (183)
The problem is… it doesnt exist. (3dsMaxDes ign\2015 - 64bit)
This is a build of V-Ray 3.10 on the slave (the date at the start of the log is Jan 8th); make sure both the client and the server run the same V-Ray versions.
i will check that
hi again…
this message is very strange. Can you help me?
*** ALERT! Could not open INI file: “C:\Program Files\Autodesk\3ds Max 2016\VRaySpawner.ini”. Using defaults.
This one’s ok, you can ignore it.
hummm… ok thanks
for me, versions are definitely the same between slaves and main workstation. and it was working until very recently.. problem approximately coincided with adding my second renderbox to the setup.
Hi again!
This happens one DR…
[2015/Jun/8|14:51:59] getting sequence data…
[2015/Jun/8|14:51:59] Extracting sequence data from RendParams.
[2015/Jun/8|14:51:59] Setting up V-Ray parameters for frame rendering.
[2015/Jun/8|14:51:59] Extracting sequence data from VRender.
[2015/Jun/8|14:51:59] Forcing multithreading
[2015/Jun/8|14:51:59] A render elements manager with 13 elements detected
[2015/Jun/8|14:51:59] Render element: VRayLightSelect
[2015/Jun/8|14:51:59] Render element: VRayRawGlobalIllumination
[2015/Jun/8|14:51:59] Render element: VRayRawLighting
[2015/Jun/8|14:51:59] Render element: VRayRawReflection
[2015/Jun/8|14:51:59] Render element: VRayRawRefraction
[2015/Jun/8|14:51:59] Render element: VRayRawShadow
[2015/Jun/8|14:51:59] Render element: VRayRawTotalLighting
[2015/Jun/8|14:51:59] Render element: VRaySampleRate
[2015/Jun/8|14:51:59] Render element: VRaySpecular
[2015/Jun/8|14:51:59] Render element: VRayWireColor
[2015/Jun/8|14:51:59] Render element: VRayZDepth
[2015/Jun/8|14:51:59] Render element: VRaySelfIllumination
[2015/Jun/8|14:51:59] Render element: VRayDRBucket
[2015/Jun/8|14:51:59] Calling beginSeqeunce()
[2015/Jun/8|14:51:59] Current project folder is “C:\Users\Andres Ahumada\Documents\3dsMax”
[2015/Jun/8|14:52:04] Loading IES file from “C:\Users\granja2\AppData\Local\Temp\vray_assets_cache\20204_c9cc6f3306897edb48fad5e9f370c346_ERCO_17993023+17265023+F54T5.IES”, setDefaults is 0
[2015/Jun/8|14:52:08] Loading IES file from “C:\Users\granja2\AppData\Local\Temp\vray_assets_cache\20204_cfc4af3cc46931f1eb8d460ec915ea3b_ERCO_34066+74493+HIT-DE_250W.IES”, setDefaults is 0
[2015/Jun/8|14:52:08] Loading IES file from “C:\Users\granja2\AppData\Local\Temp\vray_assets_cache\20204_c88d617b7aa8a0e998e59bdbf19ee9e0_ERCO_34051+74473+QT12_100W-12V.IES”, setDefaults is 0
[2015/Jun/8|14:52:54] Entering beginSequence().
[2015/Jun/8|14:52:54] Setting RenderGlobalContext.
[2015/Jun/8|14:52:54] Broadcasting NOTIFY_PRE_RENDER.
[2015/Jun/8|14:52:54] Tiled bitmap cache size set to 1000 MB
[2015/Jun/8|14:52:54] Preparing renderer…
[2015/Jun/8|14:53:00] error: Could not obtain a license (10061).
[2015/Jun/8|14:53:00] Calling renderBegin().
[2015/Jun/8|14:53:00] Sending RenderBegin().
[2015/Jun/8|14:53:00] Caching camera animation.
[2015/Jun/8|14:53:00] beginSequence() done.
[2015/Jun/8|14:53:00] Calling endSeqeunce()
[2015/Jun/8|14:53:00] Entering endSequence().
[2015/Jun/8|14:53:00] Calling renderEnd().
[2015/Jun/8|14:53:00] Calling renderEnd() on render materials.
[2015/Jun/8|14:53:00] Unloading bitmaps.
[2015/Jun/8|14:53:00] Freeing render instances and lights.
[2015/Jun/8|14:53:00] Sending RenderEnd().
[2015/Jun/8|14:53:00] Sending RenderEnd() to atmospheric effects.
[2015/Jun/8|14:53:00] Sending RenderEnd() to render effects.
[2015/Jun/8|14:53:00] Sending RenderEnd() to the tone operator.
[2015/Jun/8|14:53:00] Sending RenderEnd() to environment maps.
[2015/Jun/8|14:53:00] Sending RenderEnd() to override mtl.
[2015/Jun/8|14:53:00] Broadcasting NOTIFY_POST_RENDER.
[2015/Jun/8|14:53:00] endSequence() finished.
[2015/Jun/8|14:53:00] Closing DR session from 192.168.1.200
[2015/Jun/8|14:53:00] warning: Failed to delete server scene file “C:\Users\granja2\AppData\Local\Autodesk\3dsMax\2016 - 64bit\ENU\temp\vray_server_scene.max” (0)[/QUOTE]
