3.70.03 hotfix
Dear all,
We understand that the Save V-Ray settings pop up appeared to be annoying for many of you, especially for those of you that are working in a team environment.
We tried to respond as fast as we can to the number of requests we received from your side in regard to this matter. And as result we have V-Ray 3.70.03 hotfix which can be downloaded from our website.
The hotfix contains one particular fix for the above mentioned problem. There is an option which can be added to the V-Ray config.json file, so that the V-Ray settings are saved but there is no popup.
A step-by-step description how it works and how to set it up can be found in the following forum thread.
We encourage you to give us your feedback, as this fix is temporary until we find the solution which will work best for you.
Yours,
V-Ray for Revit team
