Hello Corona guys,
I am exporting my render output in .exr format on 3000 px. When i open my exr render output in Photoshop, it shows 72 dpi resolution. How can i get 300 dpi resolution on 3000 px image size.
Thanks in advance.
Hello Corona guys,
Thanks in advance.
It´s just a default photoshop value because ppi (“dpi” does not apply here because it´s output/printer dependend) is unknown. If you want to have 300ppi displayed in PS (why? It does not change pixel resolution or the image at all, it´s just part of the equation pixel/size=ppi) then do in PS:
Image → Image Size → untick “Resample” → change resolution to 300 pixels(!) per Inch → done. The image is not resampled this way but you have a different ppi value in the document.
The only advantage to do this is, that it may be more convenient when placing the image in some kind of layout application because the initial size is closer to what you want to have, but usually the size is adjusted anyway after placing.
You can´t set the ppi value directly from max and afaik exr does not even has some metadata for ppi or dpi.
Good Luck
Thank you very much for your message but i am looking for some information on dpi not ppi. Actually my client need images on 300 dpi for print purpose. So my question is how can i get 300 dpi for printing purpose on 3000px. i can save tiff image in 300 dpi but i can not find a way to save .exr file in 300dpi. Actually its a exterior render image and exported in exr format because with exr option i can easily add sky in background.
You won’t give to client exr file anyway, so why bother with dpi? You can add needed dpi after you convert file to tiff or some else format.
As mentioned: EXR has no mechanism to store this information. You could teach your client about the relationship of ppi/dpi, image resolution and size maybe? And: “dpi” just does not exist in this stage of production, it´s a value related to print.
Your client get´s exact the same image regardless of the ppi/dpi value displayed in PS, no data/resolution loss or whatsoever.
Good Luck
Of course, but these images are for printing purpose and are going to on a bill board. and if my image dpi is 72 and according to you,i should convert 72 dpi to 300 dpi in Photoshop manually , i am afraid that my image will loss resolution and quality and after 72 to 300 conversation my image height and width will change too.
You won’t loose anything. Read this carefully:
It will not. Read the posts again or try it yourself. Just unckeck “Resample” in the image size dialogue. Pixels will not change at all as I already wrote. It´s just some metadata in the document, nothing more.
Yes, that´s the intention of ppi/dpi. See: You have 3k pixels width for example. If you have 100ppi, your document size will be about 30 Inches. If you have 300ppi, your doc size will be about 10 Inches.
In both cases, your image has still 3000 pixel in one direction. See this equation:
ppi=pixelcount (pixels)/width (inch)
In your case, “pixelcount” will be always the same, it´s the constant. So when you alter ppi then width (size) has to change.
Good Luck
@romullus: You won this time ![]()
1:1 :]
I ran fulltext search on EXR technical specification and there is no mention of DPI or PPI. When I google EXR DPI, this thread is the first thing that pops. It almost looks like EXR has no official way to even store DPI information since the format was created for VFX where it is basically useless…
Got it. Thank you very much guys for your fast support and replies. Really appreciable.
It´s actually this one:
https://forum.corona-renderer.com/ How to save exr at 300 dpi
which is basically in fact almost the same :]
Good Luck
Ah, tha famous DPI/PPI, the singular topic where artists are equally dumb as their clients :- )
I used to answer this question at least 5 times a years on cgarchitect, but…it never saves the world.
Great answer by Frood ! You should have stopped after the first, people need to use google instead.
I’m a having a deja vu after a deja vu! ![]()
Yes Maru, but your link is about real upsampling and ppi in general if clients get crazy about absolute resolution and the usual 300dpi slipslop - something different.
Good Luck
Sure, I was mainly referring to the previous post by Juraj in this thread, and the one from the linked thread:
Clients (actually, pretty much no one, not even most 3D guys, just read cgarch and chaosgroup, the simpler people don’t get it either )don’t understand the relationship between digital input and the print process. You can print using 2400 DPI offset technology if you want, and it doesn’t matter what your input is, if it’s 600px Instagram crap, 6k px/24MP photo or 30 000 px render. It takes 10 minutes of explaining and then just sending what you find reasonable. DPI =/= PPI.
I am surprised you even tried to render it :- ) Your client probably didn’t do any mathematics, he just asked for 5 meter big 150 dpi print. Did he really ask for the exact resolution (30k) directly ? Because I’ve seen often it’s just something 3D artists assume it’s asked from them.
30k render would be ridiculously stupid, no kind of texture or geometry detail would look good at that size. And it would never render.
Ah, ok yes. Most amazingly people doing layout + preprint are frequently those who have the least idea of what´s going on. So they call their printing shop, get the standard 300dpi answer and that´s it. It´s like doing network administration without having a clue how tcp/ip works. I will never understand this even if I somehow would like to ![]()
Good Luck
