I failed to render this in the past…Max + Vray hangs everytime i press render. I remodeled it and used Max and vray again…it worked.
looks good, how long it take? Was it with 1.45?
Nope..still the old stuff. Im using a Dual Xeon 3.06 1mb cache with 2gb ram…took less than 40 minutes.
Look very nice Reza.
Please can you give show us the lights setup.
carpet is very odd :lol:
but lighting is ok
Looks great Reza .. just a little tilling on some mats …
hi reza, nice render (and nice computer!). do you have another light source like a direct light outside coming through the roof or is that a self illuminated material? very nice effect
The truth is that i remove the ceiling, and by doing so…i expose the white background. The wooden v frame below the ceiling contains conceled lights…and when they’re turn on…it will bounce the light from the ceiling and illuminate the room below…so removing the ceiling makes it look like the light are on. and since i have reflection on the wood…it is actually reflecting the white background. (not really glow from light source) and no other light were used.
Very Sweet image reza!!! My question is reza what program did you model it in. Gadzooks
The building was done with Autocad(solid modeling)imported into MAX and added the chair and materials. reason i did it in Autocad was because of major boolean operation, and the cad files were available for extrusion.
Hi reza.
nice this works now. looks good. So now do you understand why it worked now ?
and what would the rendertimes be with l-map :shock:
Tom
Man that looks really great now :!:
--Jon
Well tom..i think the main reason is that there were models/objects with errors and now im using lesser faces…previously it was close to 7milion faces…now its just about 3milion. it is obvious that max and vray can handle a lot of objects/faces..but when you have many lights with shadow on…it takes a toll on the software/hardware. im not even using the 3gb switch.
Hi reza
i´ve just read a thread where egz told about his tests of the vray geometry masses, vray can handle. His fazit was, that usualy , vray seems to be able to go up to 5 million faces, brazil up to 10 millions.
So what i tested after this was the vray proxy object. i copied an object with 16000 faces instanced several times, and ended up with
167 000 000 polygons. :shock: it was rendered only with raytrace shadows, and without gi in about 1 and a half minuts. well i didnt test it with gi, but maybe your scene with those seats would have been a nice testscene to for this.
in my next scenes with lots of 3d trees i will take advantage of this.
by.
Tom
please post your results…im doing the same.
Tom, can you please post the results of that 167M polys as well?
Thanks in advance.
here we go
here you see the memory amount used. it only depends on the amount you did give in the rendersettings at the dynamic raycaster. here i used 400 or 800 mb. together with the opended max and windows, i got something about 1 gig of ram usage.
this scene was with standart antialiasing no gi.
this scene is lightmap only, and much less geometry, but still very much renderprimitives where constructed on rendertime. memory usage is higher, because i turned the dynamic raycaster amount up.
the rendered immage with lightmap (not so beautiful, but a technical test
) about 4 minutes calculation
a real heavy scene now :shock: rendertime about 18 minutes.
sorry i forgot to write in the frbuffer stamp the rendertime.
at last happy testing
the maxscene
http://www.tom-schuelke.com/proxy.rar
and the vrmeshfile.
http://www.tom-schuelke.com/vraymesh.rar
Tom
holy .. these are many primitives :shock:
