300dpi renders in Vray?
Is it possible to render higher than 72dpi in Vray? say, 300 or 600dpi? The standard Maya settings allow you to change the dpi, but when Vray is enabled, that option is gone… Any ideas?
Thanks in advance!
DPI has no affect on the image. Just go to Photoshop and change it to anything you want.
its width X dpi and height x dpi so, if you want 8.5" x 11" @300 dpi, you would render out at 2550 x 3300
In max there is a print wizard which allows you to just specify dpi and it configures your render res for you.\
Edit. Nvm this is in maya :smile:
It’s in Max as well =) Rendering / Print Size Assistant.
