So this is something that’s been bothering me and I can’t solve. Maybe it’s just photoshop maybe it isn’t.
Whenever I save an EXR, I do some photoshop work with reflection passes and such, then I want to apply a camera RAW filter in 32 bit but my image is immediately overexposed or wrong gamma, don’t really know. I merge everything and convert to 16 bit and camera raw looks fine then (but without all the 32 bit information)
I just saw a video of a guy NOT having that issue, he goes into the camera raw filter in 32 bit and his image stays the same. Am I saving my EXR wrong or something? I just click save all channels; that’s it. The options are taken from when you save only one channel I guess and those are 16bit halffloat. I work in LWF; gamma isn’t baked and sRGB is ticked in VFB, so the defaults.
Are there some settings wrong in photoshop perhaps.
So it appears to be normal, here and there. And whatever 32 bit filter or adjustment you do it changes to 8bit. I might try/learn fusion to do my editing.
the image in the YT video changes slightly. expo and contrast I would say. quite similar to what I’m experiencing. I the change is huge the case might be the auto gamma thing in max - I always save my exrs with gamma overridden to 1.
Doesnt Camera RAW open/convert your EXR as a TIFF, then when you open the file, it translates the adjusted TIFF back into the orginal format, in this case an EXR?
Same problem here and have been pecking around for an answere here and there for about a year now, w/out much luck. In the mean time, I’ve resorted to just doing exposure adj in 32 Bit. Saving a 32Bit PSD file, then live linking into an 8 Bit PSD file. Then Applying camera raw filter. Biggest reason I liked having camera raw on 32 bit images was to compress the highlights in a more natural way.
