Hello!
does anyone have experience with the “problem”:
32bit -direct export from AE works fine -but there is no H.264..
I can´t find settings or soloutions to get a correct linear color output from Media Encoder..
(system: windows10 / AE 2020 )
No, H.264 is a no go, H.265 yes, or… If you haven’t yet done any research on video containers & codecs, I suggest reading: [best format to publish raw video? (@ Magic Lantern Forum)
](https://www.magiclantern.fm/forum/ "Use as render view" is used in editor rendering )
Thank you for the link and h265 tip -its an older interesting dicourse of codecs and the need of high bit´s..
-H265 is also washed like every codec -the Problem is Media Encoder its not working with 32 bit (even if I use avi or exr)
I found a 32bit workflow tutorial for redshift and blender -partly with plugins and transmission of luts ..but without the explanation of how to export
AE renderque´s quicktime is to dark.. avi export is perfect but after re-import its to dark..
Is there a clean solution? if 32bit needs tons of extra software and knowledge i have to go back to 8bit workflow.
Ok, strange but this work:
-export with AE render queue (Avi)
-import to Premiere
-export from Premiere AME
