32bit:Batch render & color Mapping & white balance
hi,
i’ve a problem with batch render.
If i render from render globals and i save in .hdr format i’ve the right image except for gamma correction(but this it’s not a big problem, i correct later into Photoshop)
If i render from batch render and set an .hdr/.exr image as output file i obtain a wrong result, i loose white balance and color mapping (reinhard) but gamma correction is right.
Anyone can confirm this??
I’m a batch render addicted…i hope it’s not a bug.
Thanks in advance.
do you use batch render with net render?
no…
single rendernode
from menu → batch render
no net batch render
hmm weird then.. i have no idea :slight_smile:
