32bit EXR clamped in CoronaColorCorrect
Hi all,
I am working on a very complicated project and this morning I noticed something strange when I use a Quixel 32bit EXR Displacement map (loaded via CoronaBitmap) + CoronaColorCorrect.
  1. When the CoronaBitmap is loaded by itself in the Displacement slot, everything works fine.
  2. When I apply a CoronaColorCorrect on the above Displacement slot, the result is wrong it seems that a lot of the EXR information are clamped.
I attached a fast preview image, on the left the correct result with the Displacement 32bit map alone, on the right the fault result by using CoronaColorCorrect on it.
Thanks,
Dionysios -
I am afraid I can’t reproduce this, I’ve tested three different EXR’s from quixel all produce the same displ value. Autobump on/off, 2.5D on/off , screen size/ world size.
Can you share your scene with no materials? What version of Corona you are currently using?
Thanks for getting back!
Unfortunately I can’t replicate this as well here in the office. I am really sorry.
The problem appeared to me last Saturday while I was working at home so I need to check that again tonight.
I use the latest build by the way, excuse me for not mentioning this before.
Thanks and I’ll let you know news.
Dionysios -
Hi, luckily I as able to reproduce the bug at home.
Probably is this kind of Displacement map got out from Quixel Mixer? I don’t know, without the Corona Color Correction on it, it works fine.
Here is the file (3ds Max 2020), on the left the correct version, on the right with the defect: Microsoft OneDrive
Used the latest Corona daily build.
Please let me know once download it so I can delete it from the cloud.
Thanks,
Dionysios -
Hi Dionysios, thanks for the update and for sharing the scene, feel free to delete it from the cloud.
So indeed, there seems to be an issue with this displacement EXR + ccc, we will look into it further and report back if it’s a bug or something different.
Thanks for bringing it to our attention.
(internal id=476690362)
You welcome and thanks for your support.
I noticed too that is happening for now with only this Displacement map but I don’t know the reasons.
In any case I am curious and looking forward to receive any updates.
Thanks again,
Dionysios -
One workaround seems to be going to Output rollout of the displacement bitmap and increasing RGB Offset to 3-5 and then adjusting displacement strength in the material manually.
Another thing that seems to make it work, don’t ask me why. :smiley:
Thanks Maru, things are a bit more complicated… :smiley:
I am working on a very complicated terrain model and I am using a Corona Layered Material with 5 different Displacement maps and masks.
Due to the limitation of the engine to treat differen Dipl. maps in the layred material in the same time, I am using the mix map method so the displacement main strength is set to the main material and all the others are modified by their RGB values. So I need to change the RGB offset and not the RGB level to achieve a correct result?
Thanks,
Dionysios -
It probably doesn’t matter - whatever works.
But maybe the other option with a Mix map would work? (as in my screenshot)
First of all thanks!
I wanted to use the Corona Color Correction only for the Displacement amount via the HDR Color value cause I thought would be more precise.
Now that I can’t use that combination I simply use the RGB Level in the Bitmap menu.
