360 panorama stitch problem
Hi
I have problem with different lightness on edges of spherical images rendered with Corona 5. It’s clearly visible on the seam on opposite side of the camera target.
Rendered the same scene with Corona 4RC3 and didn’t get these kind of artifacts
Hi, are you using denoising? And if yes, which?
Yes, these pictures denoised by Corona HQ denoiser
Are you using the High Quality filtering? If so, please try and switch to Tent filtering and see if this solves the problem.
Thanks,
Rowan
(Internal ID=388981894)
Yes, I used HQ filtering. I’ll try Tent
Okay, let me know how you get on, we are aware that this kind of issue can happen with the HQ filtering and we are working on a fix.
Rowan
Pictures rendered with Tent filtering do not have these artifacts. I’ll go on with it until this problem of HQ filtering will be fixed. Thanks
This is fixed in the latest v8 daily build. You can grab it here: https://forum.corona-renderer.com/ Corona Renderer 8 for 3ds Max - Daily Builds Changelog #msg194990
Cheers,
Rowan
