360 spherical Stitch line
Hi.
We are almost always seeing a seem or Joint in stitched VRs which are saved out of vantage. this issue is there since quite some versions. I am attaching couple of images and sending you link of vrs in zip file. check it out. we render at 6000x3000 non stereo … this problem is a big headache for us, as we do a lot of Vr.
Thanks.
Hi vishwanath_mani,
I believe this has something to do with compression or similar, still investigating it, will write back when we have something. Have you tried with different file types - png, jpg, exr?
Alexander
This seam could also be caused by the NVidia AI denoiser. As already mentioned in this thread here: spherical rendering - Vantage :: General - Chaos Forum. Can you try and render the panorama without the denoiser enabled and see if the seam persists?
Alexander​
Just noticed some seams also in my 360s, however they are not continuous…they fade.
Did anyone try this without denoiser and did it resolve the issue?
I’ve noticed if use the apply to final image option the seam seems to go away.
A year later… I think we figured it out: spherical rendering - Vantage :: General - Chaos Forum
