The program is crashing all of a sudden from the very beginning. Looking at Autodesk help they pretend that the problem is related to Corona Renderer which is obviously stupid: 3d max was working yesterday with Corona. As we get used in last 10 years Autodesk is making a really mess with tones of updates and wrong software.
Here is the article: https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Crashes-or-instability-occurs-when-rendering-with-Corona-in-3ds-Max.html
Should I try to uninstall Corona … ? Is there any fresh Corona update? I do NOT believe the problem is caused by Corona …
For crashes, best to send as much info as possible to support, including the minidump - see https://support.corona-renderer.com/hc/en-us/articles/4402983255313-How-to-report-issues-3ds-Max-
We’d also need Max version, Corona version, what you were doing specifically at the crash, whether this is all scenes or just one scene - the more info the better
Go to:
C:\Users*YOURUSERNAME*\AppData\Local\Autodesk\3dsMax\2021 - 64bit (or whatever version you have).
Move the ENU to the desktop and restart 3dsmax. If it works that means you have a corrupt file in your ENU folder. You can copy/paste settings back but always good to keep a working copy of this folder.
