There’s loads and loads of stuff, some of decent quality and some poor.
As I was looking for posed figures, I found quite a few. Many come as 3ds files, complete with texture folders. You need to separate the meshes and assign materials, so it might take a while.
Maybe we could collect some links here - together with some results? (not sure whether there’s a thread like this in the Rhino section already…)
>>>> Please do not click on the link if you are offended by nudity<<<<<
since from what I understood it seems to be legal to download and use the stuff for your projects, still there are 2 things that are a bit problematic…
1) Polycount → but its OK if you use them only for foreground placement…
2) The amount of time to reconnect the textures manually… → what if we could share this work, put all the Rhino file versions into one single space where we can all download…? We should put the textures in the same directory as the rhino file, since it seems that they are recognized there automatically although the link is pointing to a local drive…
;D ;D ;D
your image gave me a huge laugh, brilliant!!
;D ;D ;D
it seems to be a really good idea to collect such a library, but it might interfere with their legal aspects…
It took me some 20mins to re-assign everything and save it to my object library.
As you said, the polycount of most figures is too high to put them into the background, so a project might only need one or two models at a time.
