Is it possible to use the new Vector Map as a displacement map. I am trying it right now, but it won’t work. Just curious ![]()
Ralf
Ralf
It doesn’t work on my side too - will add it as a feature into our system.
Edit: Actually with VrayDisplacementMod in 3D Mapping Type with Vector Displacement option activated there is some Displacement but it doesn’t look very accurate.
Thx for this, the color correct willdo it then. I tried it with an Output Node ![]()
Thx a lot
Ralf
I guess that it will work with Output Node too.
This is actually expected result- vector file formats don’t have any anti-aliasing between pixels, the edge between the text and the background is very hard.
In order to get such crisp displacement you have to increase the tessellation a lot - some filtering will also help out in order to get smoother results.
Feel free to send us this scene for investigation if you have difficulties with getting a better/cleaner result.
