Hi all,
Sorry if this is a dumb question, but I just got this email from Autodesk:
Dear (me),
Choose your 3ds Max by 5:00 PM PST on Thursday, February 26, 2009.
Last year, as an Autodesk® Subscription customer, you received Select Edition of Autodesk® 3ds Max® 2009 software that allowed you to install either Autodesk 3ds Max or Autodesk® 3ds Max® Design. Now that you’ve had the chance to try both versions, it’s time to choose which 3ds Max is right for you.
This year, we’re giving Subscription members a limited, one-time opportunity, to cross-grade licenses from Autodesk 3ds Max to Autodesk 3ds Max Design (or vice versa)* at no additional charge.
Make your choice now by clicking here.
Discover the differences between Autodesk 3ds Max and Autodesk 3ds Max Design by clicking here.
Thank you for choosing Autodesk Subscription.
Autodesk 3ds Max Product Team
I’m not real crazy about the idea of a product split, because it means plugin developers may have extra work to do to check compatibility. That and the fact that it serves no purpose except to make more money for Autodesk when companies may need to buy both versions in the future.
Just wanted to make sure that Chaos group plans on making future versions of vray compatible with 3dsmax Design. There is no guarantee that Autodesk won’t split off the code base at some point, even though right now they are saying the two versions will be built off the same binary.
Here is a FAQ on the difference between versions:
Thanks.
P.S. Any plans for an upcoming XSI vray release?
