3ds max 2015 crashes when have two instances of max open
tested it with the lastest daily build and it seems corona is the cause, running 3ds max 2015 and windows 10, anyone else seen this issue?
Which daily build is that? Are you sure it’s the newest one? This was already reported and should be fixed, unelss it’s some different issue.
Its the newest nightly build, i forgot the number since i uninstalled it, which build do you thing is safest to use?
this was fixed in tha latest daily, can you double-check it you have the latest one?
i uninstalled it because i couldnt work with it, today i will use it for a project so i will install the newset one and report back here, thanks!
Funny enough, it crashes for me if I run DB and then 1.4, but it runs fine if I start 1.4 and then DB. I am using this method to run different versions at the same time:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000577837-how-to-run-different-corona-versions-at-the-same-time-
Running 2 x 1.4, or 2 x DB is ok.
Minidump:
DB-14.dmp (702 KB)
