3DS MAX 2015 Select hell
I am sure you have experienced elements not being selected, when you select them, but is there a fix? It’s costing me a ton of time to selecting, delete/move/copy…, zoom and select again, and again…0
You get used to it :slight_smile:
It is a nightmare.
are you using SP2?
yes, I think so. I’ll have to double check.[quote=“svetlozar.draganov, username:svetlozar.draganov”]
are you using SP2?
[/quote]
I have had a few issues with 2015 and at one stage I deleted my 3dsmax.ini file and it seemed to fix quite a few problems.
I find that it’s a little better if you’re in wireframe
It’s what you pay subscription for - so they can fix things they broke last year and break things to fix next year.
I went back to 2014 I could not stand the selection bug. Autodesk said it due to an issue with Wacom and Spacemouse drivers and they are “looking into it”
I don’t have either the Wacom or Spacemouse, so they are looking at the wrong thing.
Yes. Also zooming lets you get another stab at it, zoom again for more…[quote=“dlparisi, post:7, topic:46310, username:dlparisi”]
[/quote]
Try this…I found it on the Area forums it seems to help with the selection bug.
NitrousGraphicsManager.HardwareHitTestEnabled = false
I’ll sure try, thanks.
i can confirm this works :slight_smile:
I guess it worked for me too, not that I think about it. At first I thought it had to be done each time, but maybe not.
