3ds max 2019 - Framebuffer freezing and other tabs randomly popping up when i start a render - UNUSABLE right now please help
Oh no!
Started my first print renderings in max 2019 and suddenly it`s going crazy.
when i render some larger resolutions the framebuffer is freezing and other tabs randomly popping up when i start a render - UNUSABLE right now please help
i`m not even able to chancel the render but it seems it`s rendering still
anyone else discoverd that behavior?
Seems like the issue described in this thread:
https://forums.chaosgroup.com/forum/…-3-6-vfb-hangs
and there are some workarounds here:
https://forums.chaosgroup.com/forum/…884#post975884
Yavor
Ah ok ok, it was a old scene from max 2016 which had not set the memory limit to 0, when i changed it all is working… puuh sorry for panicking…:roll_eyes:
Hi Yavor,
thanks for super fast help and the very interesting links!
But two things still bothers me right now, is the low priority set in vray settings tab gone in vray next or am i blind?
And when i render the scene, statistic info shows me that it is swapping memory somehow, i didn’t see that for a long time.
Don’t know if it makes sense and when what is causing the memory swap into virtual memory…
There is a thread for the Low Thread priority option here:
Not sure about the swapping - what message do you get ?
I think it’s normal - the V thing is about virtual memory used by Max. Virtual here doesn’t necessarily mean swap - it’s parts of the memory requested by the process that are not in physical memory yet. For example if the app requests a big chunk of memory but only touches a part of it - some of the rest might remain only virtual and not go to physical memory at all.
Hi Yavor,
thanks for explaining, really appreciate it!
