hello, i just installed 3ds max 2021 and I installed corona v5.The program closes when i start rendering. I tried it in different scenes and in empty scenes. I had no problems in 3ds max 2020 and corona v4 before, Please someone help me. Healthy days…
Did you install newly released Corona 5 Hotfix 1? https://forum.corona-renderer.com/ Corona Renderer 5 for 3ds Max (Hotfix 1) released
This sounds like a strange situation where a license reset my fix the issue.
Please remove all files in the following location: C:\Users\USERNAME\AppData\Local\CoronaRenderer
The re-install Corona and see if this helps.
Thanks,
Rowan
Download | My Chaos I downloaded from the link today. I did not update any further
corona v5.wmv (4.96 MB)
Thank you Rowan. The solution you said worked. No problem anymore.
It is solved also with te last 6.0 beta?
becouse I notice, with max2020 scene, an error in mrmaterialattribs.gup. If I skip error, and do nothing, corona render works. If in 3dsmax scene converter I clear all mentalray plugin error, when start corona render (also interactive) crash.
Please create a new bug report for this. It sounds like a different issue to the one reported here.
Rowan
