I am using 3ds max 2024, color management set to Gamma 2.2, vray display correction set to sRGB in VFB, save image 16bit TIFF using batch render, the output image look greyish, how to solve it?
To be honest, I’m really annoyed with the whole colour management system. I went from Max 2024 Vray 6 to Max 2026, Vray 7. Had to do a lot of Forum reading and tral and error just to get back to predictable colour output, and opening a render in Photoshop that looks the same as what appears in the VFB. As above, I’m using Gamma 2.2 display correction.
agree, sometime it put me back to 3ds max 2023, easy to get correct result.
Is the output result similar to what is displayed in the VFB if you set the Display Correction to Gamma 2.2 (instead of sRGB)?
If I set to Gamma 2.2 the result is same as VFB displayed, but I want it to be same as sRGB, because more contrast.
Then, choose a linear format such as .exr, open it in PS, and export with “Convert to sRGB” and “Embed Color Profile” on. You can do this in Chaos Player, too - just open the image and re-save it as .tiff.
How to save in linear format? can I save it as a 16bits TIFF before open it in Chaos Player?
Save as .exr or .vrimg. If you save through Separate Render Channels or via the VFB (except raw files), 3ds Max will apply a 2.2 gamma, not sRGB. That’s why:
1. Save image as .exr
2. Open image in ChaosPlayer / PS
3. Export as TIFF
Normally I save file using 3ds max btach render, so what can I do? please guide me step-by-step, thank you.
1. In the Batch Render Output Path, choose .exr or .vrimg
2. In the browse window (below the Name template), set Gamma to Оverride = 1.
3. Render
4. Opеn image in Photoshop (via EXR-IO plugin)
(5.) Switch Photoshop Color Profile to sRGB (Edit > Assign Profile); It should be RGB-built-in / sRGB IEC61966-2.1
6. Go to File > Save a Copy
7. Choose “Save as type” to .tiff
8. Make sure the “ICC Profile” is checked
9. Image should now be saved with a baked sRGB profile
I really wish this could be done natively by just saving it from the frame buffer
Is the “Convert to sRGB”, “Embed Color Profile” and Assign Profile work the same way?
They do different stuff:
“Assign Profile” - this controls the color profile used in Photoshop itself.
“Convert to sRGB” - this bakes the sRGB profile onto the image.
“Embed Color Profile” - this writes some metadata about the profile onto the image so that other software can recognize it.
Thank you for your explaination
I’ve just had this problem today and I resolved it by doing the setting on the attached image. I believe the default setting is incorrect in 3dsmax and it’s not picked up in the Vray docs, the Conversion bit under the Render Output Defaults was set to Display / View-Transform thus I believe introducing double ACES .
As others have said you also need to bake in the Save RGB primaries conversion to image under the VFB Display Correction.
Good luck.
Jason
Thank you for your explaination, but that is not my case, mine is Gamma 2.2 issue. I did not use ACES because AI Enhance not support ACES workflow, in a everything need to be fast, I rather choose a easy way to delivery my work.
It’s covered in the 3ds Max OCIO defaults article.
Thanks @hermit.crab , my misunderstanding of the process and apologies for not finding that explanation document, all working well now.
Thanks again.
Jason
Why is there such a colour problem with 7, I have use PS to get the colour correct in 7, didn’t have to in 6…What did you do. if it isn’t broken don’t fix it.
