I’m having ongoing issues getting Corona to work properly with 3ds Max 2026, and I’m hoping someone from the Chaos team can help me resolve this.
I’m running 3ds Max 2026 with Corona 15, and initially started receiving the following error on startup:
DLL <C:\Program Files\Autodesk\3ds Max 2026\PlugIns\CoronaMaxUtils2026.dlt> failed to initialize properly - not loading.
I attempted troubleshooting by adding the CORONA_3DSMAX_2026_LOAD_PATH environment variable, following advice I received, but this resulted in a Qt platform plugin error. I subsequently removed the environment variable, restarted my PC, and 3ds Max opened without the original error. However, Windows then displayed warnings about being unable to verify the publishers of qgiflegion.dll and legioncefviewingwing-cef-113.3.1-release.exe.
After reinstalling, I’m now receiving another DLL initialization error on startup:
DLL <C:\ProgramData\Autodesk\ApplicationPlugins\ChaosScatter3dsMax2026\ChaosScatterMax2026.dlt> failed to initialize properly - not loading.
I’m concerned that there may be an issue with the installation, plugin compatibility, or shared dependencies, but I haven’t been able to establish the root cause.
At this point, I’m looking for a clear, reliable solution from the Chaos team. I use 3ds Max professionally and need to get my working environment stable again without risking my existing projects or settings.
@Lois_Schwartz Hi, after one of Windows Updates, Windows became much more sensitive to “suspicious” files. The only workaround we are currently aware of is:
Note:
This involves changing Windows security settings - please check the exact effects it causes, e.g. here and here
Depending on your exact Windows version, this may not be undoable (the change may be permanent)
In Windows, go to Privacy & security > Windows Security > App & browser control
Under Smart App Control pick Smart App Control settings
Set it to disabled
This should prevent Windows from blocking Corona and other Chaos-related files.
We are already working on resolving this on our side. (CMAX-2568)
I have had almost the exact same issue with 2026 & 2027. It started 2 or 3 weeks ago. First I got the qgiflegion.dll error, then a few days later it wouldn’t load the vray plugins, then today (23/10/26) it wouldn’t load the corona files, but now would load the vray files. I tried mutliple times to relaunch but got the same errors. I restarted my pc, launched 3dsmax, no errors…
Sounds like it’s a know issue and a ptch will be coming soon (?)
There’s Corona 16?! Is this an official release or a daily build? It would be great if we could get the ‘announcements’ back in the forum that tells you when all the updates happen - I have only spotted the daily. At the moment, there is no way of finding out when an official build is released - or maybe I just can’t find it. Maybe Corona could check when launched for the latest version, a bit like Forest Pro.
Thank you for the response and clarity - appreciate it. I must admit, I’m somewhat nervous to install the Candidate release if it’s still in development. For now, I am managing the issue by turning off my internet connection and starting up the 3DS Max. I will continue doing that until the development is complete @maru
