Setup:
- 3ds Max 2027 - 29,0 - 29.0.0.3590
- V-Ray 7.3 (vray_73003_max2027_dr2_x64_stable_33571.exe)
- Backburner 2019
- 5 render nodes, all same software stack and same versions as above
- Previous and currently working setup: 3ds Max 2026 + V-Ray 7.3 DR2 (vray_73002_max2026_dr2_x64.exe) — fully functional
[/HR]
Problem:
After upgrading to 3ds Max 2027 we are experiencing two separate but related issues across all 5 render nodes in 3ds max 2027:
- Backburner returns pipeline error 109 on all nodes regardless of renderer (tested with V-Ray, Arnold and Scanline)
- V-Ray Distributed Rendering times out when connecting to render nodes
- Vray Version Mismatch Using latest stable build vray_73003_max2027_dr2_x64_stable_33571.exe gives an mismatchWarning in the log*: “Server 172.xx.xx.xxx:20208: VRay version mismatch: VRay builds mismatched: partner’s version is 7.30.0.3 while ours is 7.30.0.2 - cannot interoperate in distributed rendering”*
Even if both are freshly installed.
Both works perfectly on the same hardware and network with 3ds Max 2026 and with Vray 7.3. (vray_73002_max2026_dr2_x64.exe)
[/HR]
What we have checked and ruled out:
- Network connectivity — ping successful, all machines on same subnet
- Firewall — ports open and confirmed
- IP/hostname resolution — PC names resolve correctly
- Licenses — all available and accessible
- V-Ray spawner — confirmed running and listening
- V-Ray builds — matched across all nodes
- Renderer — Backburner fails identically with all renderers, ruling out V-Ray specifically
[/HR]
Additional findings during troubleshooting:
- The V-Ray spawner port default appears to have shifted from 20204 to 20208, and in some cases the spawner was found listening on 20209 rather than the expected port
- Backburner log shows ADP Failed to start and adapter returned unexpected code -2 before the pipeline 109 error — suggesting 3ds Max 2027 is failing to initialize properly on the nodes
- DR works correctly in 3ds Max 2026 with the latest V-Ray build on the same machines — confirming this is specific to 2027
[/HR]
Question:
Has anyone else encountered Backburner and/or V-Ray DR being broken specifically with 3ds Max 2027? Is there a known compatibility issue or a recommended fix? We have not been able to find anything online when searching the forums of both Autodesk and Chaos Group.
Any help appreciated.
This has been posted in the Autodesk forum as well.
[/HR]
