3ds Max 2027 with V-Ray 7.3, the VFB LightMix Source Properties panel, UI Scale
In 3ds Max 2027 with V-Ray 7.3, the VFB LightMix Source Properties panel, the lights layers look much taller compared to previous versions (max26 vray7.3) and takes so much space. I tried VRAY_VFB_UI_SCALE but did nothing. Any solution for this?
That variable, I think, is Rhino/SketchUp-specific. Otherwise, there are no real UI changes in the VFB. Mind if you show a screenshot? Perhaps you have some Windows Scaling?
Spoke to the devs, and it turns out it is an issue on our end specific to 3ds Max 2027 (we still use Qt from 2026). We’ve already logged the issue (VMAX-15464).
Thanks for the update.
