Looking to see if anyone is running max 8.x on Windows 7 successfully? I installed it. I installed it and everything went fine but when I try to open it it seems to load fine and then just after it gets the main GUI loaded it hangs and does nothing. Ive tried running under administrator and or compatibility mode… and still hangs with no obvious errors coming up… Anyone else running this combo and working or can I give up with the task that has been assigned to me to get this running :S
UGH! This is going to be a pretty tall order. I remember having a fairly rough go with Max9 and Windows 7. I think I still have my Max8 disc around here somewhere I could try and install it and give it a go. I am assuming that you are running Windows 7 Pro 64bit?
I would start with compatibility mode, like you mentioned and make sure that you run Max with the software display driver instead of the DirectX or OpenGL.
If I HAD to use Max8, I would NOT leave XP. But that is just my 10 cents.
Thanks guys, I got it sorted out late last night by dropping in a new video card :S dont know how that would affect it but it had a 7800GTX and dropped in a 8800GXT for sh!ts n giggles and OMG it worked lol. Its not my workstation, its actually for my fathers workstation and Im trying like mad to get him in to max 2010. Anyway its all good now and running great.
LOL yea Im not sure why the card made a difference unless it was actually bad but the 8800gtx and new video driver seemed to help. going to run more test tonight hopefully but all seems well and all that I have for start up OS options are run as admin, and don’t have compatibility on.
