I’m using 3ds max 2025 (the latest version I download from Autodesk) and Corona Render 12 Update 1 (hot fix 1) (the latest version I downloaded from Chaos).
The problem is:
My .max file can not open on another computer. I received “Application Error - An error has occurred and the application will now close.”. But this file is still open property on my computer.
I’m not install Scatter, forest pack, floor generator etc.
But max files I created from PC (A) are still can not open on PC (B)
This is a report and minidump files. Hope you can help me to solve it
Just to make sure - both machines have exactly the same version of 3ds Max and Corona, right?
While we check this, can you please try merging the scene part by part - this will greatly help to understand which part/object exactly causes the crash.
The minidump reports Corona version which is older than Corona 12 update 1 hotfix 1.
Most probably you don’t have Corona 12 update 1 hotfix 1 installed on the machine where the scene crashes on open.
Please do a clean uninstall/install of Corona 12 update 1 hotfix 1 and try again.
