3ds Max Crashing/Freezing Opening Bitmap File Explorer
Ive trying to convert over from Fstorm to Corona on the trial version. Constantly freezing and crashing on me. Is it Fstorm materials mucking it up? Is it just 3ds Max? Can I submit a dump file please? Ive already run the Scene Converter. At the moment Im consolidating my bitmaps into one folder.
UPDATE: I went ahead and used a script that clears out unused plugins, objects from the scene, material renamer, etc. Its called Sini Forensic. It seems to have helped. I will update is theres a change.
Sure you can “officially” report the issue to us with a minidump. See: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
If it’s randomly crashing and/or there are other issues with rendering and the material editor, it may be also helpful to perform what is instructed under point A.3 here: https://coronarenderer.freshdesk.com/support/solutions/articles/12000015667
