3ds Max Lens Flare Effect in Corona
As 3D Designer this is my first topic on this forum site. I use 3ds Max 2017 in combination with Corona 1.7. (Demo)
Now I have a question about the Max lens flare effect. Under < Environments and Effects> tab Add I select
. Under I select Ray. (So far so good …)
Under then <load) And select < Rays.lzv> The I pick the Corona Light I have created before.
And then I close the dialog box. When I render I get a error: see attached Image.
How can I repair this message ? I know how to repair it in Max, but not in Corona
Guus
I would restrain from using the 3ds Max lens effects at all. Those tools were developed millennia ago.
The error message seems to hint that the lens effects cannot be used with 32-bit formats. The solution might be switching to some standard 8-bit format like JPG, however I cannot guarantee that it will work.
