When using a mix map in the diffuse in 3DS Max, everything is ignored and the resulting Unreal material is black after importing. Unreal 2.21, Max 2019, Vray Next 1.1.
Did you try right clicking the material and switching “Render material from .vrscene:” to ON? That fixed most of my problems.
Hi, TheMuff
The MixMap texture is not yet supported on import in Unreal. We are constantly updating supported features, materials, lights and geometries both for import and in Unreal so please check the Announcement section of the forum for new features in latest builds or for the supported features in the documentation here:Supported Features. For a current solution you can try what 8080ff suggested and try the “Render material from .vrscene” feature of the material.
Alexander
Hmm.. that’s an important feature. Lot’s of materials will be created with Mix - can’t wait to see that update. Keep rocking - cheers!
ps: looks like Tiles is also not supported yet!
Hi, Bernhard
Yes, you are correct and it is in our to-do list and will be available in future builds.
Yes, any procedural or layering texture (e.g. mix, composite, noise, tiles, cellular, etc.) is not yet supported, but it is in our to-do list and will have support for it in future builds.
Alexander
okay, okay… sooo.. what you think would be the best solution to create procedural shaders that are also supported in Vray Unreal?
I guess… for example… it might be useful to create PBR shaders with 3dcoat - then you get all the texture maps and you don’t need to worry about max oder maya procedurals.
right?
anything you would suggest?
it’s anyways always a pain to create such shaders from scratch inside of max, maya, etc.
if you have any other great tools you can recommend to create fast procedural PBR’s … please share…
thank you so much!
cheers
Hi, Bernhard
Well, anything that works with procedurals and then export a texture of it really - Substance Pinter, Designer, Alchemist, Quixel Mixer, 3DCoat, Mudbox,etc. You can also use the Max Render texture feature in the material editor to condense the material from complex shading graph to just a few textures. This workflow of using baked textures are also render time friendly. For example that that metal material on the left which is composed of many composites blends can be condensed to the one on the right which look pretty close to the original and render nearly 50% faster.
Alexander
Hi Alex!
yeah cool. got it. so basically every tool that allows you to create PBR’s and exports at the end the maps.
hx man and keep rocking!
cheers
