I’ve run into a weird problem in 3ds max 2016.
Until now, the object selection worked great in wireframe mode - I clicked on any visible wire part of an object and it got selected.
For example, if there is a table in a room enclosed by walls, in wireframe mode it’s possible to select the table with one click.
Now, suddenly, I have a scene where anything that is enclosed within another object needs 4~5 clicks - first ones always select the walls around it or whatever else is ‘in front’ of it.
Since I haven’t had this sort of problem before, I assume I must have done something by accident to make it behave this way. Does anyone have any ideas how to revert to the old behavior? Merging all the objects in new scene doesn’t fix the issue.
