Hi, apparently the 3ds Max Physical Material is not supported by V-Ray 5 GPU. This puzzles me, because the entire point of the Physical Material is maximum compatibility with all PBR renderers. Please add support for the Physical Material in an update. Thanks!
The VRayMtl supports the PBR workflow. There is a parameter for controlling the metalness and for roughness (check ‘Use Roughness’ in the BRDF rollout). If you need AO, multiply the diffuse map with an AO map via a VRayCompTex node and plug it in the diffuse Diffuse slot. Additional information here.
It is on the “to do” list to support the Physical Material in V-Ray GPU and we’ll get to it soon. In the meantime you can convert the Physical Materials to VRayMtl materials using the V-Ray scene converter.
Thanks guys, I knew about the workarounds you mentioned. I just want to be as renderer agnostic as possible, and avoid using renderer-specific materials. Glad to hear that GPU support for the Physical Material is in the works.
Best wishes,
Aaron
Hey, until the Physical Material is compatible with V-Ray GPU, can you guys mark it as “incompatible”? It’s showing up in the Material/Map Browser, even though it’s not compatible with the current renderer. Really, it should be hidden when V-Ray GPU is active, and only shown when V-Ray CPU is active.
Thanks.
And of course, supporting the Physical Material should also mean supporting the PBR Material, which is merely a stripped-down version of the Physical Material.
Thanks again.
