Hello everyone,
I’m facing a frustrating and recurring issue with Corona Renderer in 3ds Max. As you can see in the attached image, my render is not starting. I’ve waited for over 8 minutes, and the renderering passes did not started yet.
When I check the Task Manager, I see that the System Idle Process is using most of the CPU, while the Corona render process is consuming very little. My RAM usage is also low, I have 128 gb, and only using 65 gb .
This problem sometimes goes away if I restart the windows, but it quickly returns, which is making my workflow very difficult.
What could be causing this, and how can I fix it permanently? Any help or advice would be greatly appreciated.
Thanks!
