3ds max - Skip existing images
Just a small question:
So I rendered a sequence of files and I saw one render node had made black images.
I deleted the black ones and opened max, send it again to backburner and put skip existing images.
I see from backburner monitor that it assigns about 50 images per node, as in: node1 0-50 - node2 51-100 - node3 101-150…
Is it possible to change this ~50 value? I think 5 or 10 per node would be good.
I have nodes which have different cpus and I would prefer if the faster ones would render more images.
Hello naikku,
the amount of jobs BB assignes to a node depends on the rendertime of the previous frame(s) and is handled dynamically. I know of no option to change the balance between rendertime and assigned tasks.
But you can disable task blocking for a job completely:
While submitting a job: Advanced settings button in job asignment window → Job Handling → Enable task blocking
Existing job: Right mouse klick on the job in Queue Monitor (or Ctrl-J) → Enable Blocking Tasks → No
Good Luck!
