Hi! so here is my issue.
I need a timelapse effect of some people walking in an out of a building.
That would be fine, where it not for the camera is in movement over 300 frames. it is a slow path constraint
So we have to make a animated HDRI, and people walking super fast, but the movement of the camera stands the same.
We are trying to figure this out by using Populate flow.
The issue I encounter is the need to render waay to many frames only for the populate people seperate from the rest of the scene.
Is there another way to achive this effect?
I tried to render out every 15’th frame, but After effects keep grinding in my face that frames are missing.
Best regards
This would be the simplest solution and close to “reality”. If you load every X frame into AE just make sure to tick “force alphabetical order” when importing the sequence.
Premiere pro has a feature called posterise time where it plays back at the original framrate but lets you adjust the input framerate. This will do exactly what you want with a piece of smooth footage.
