3ds max vfb darker
Hi Guys,
I have a problem that I am trying to figure out. When I save a render from the 3ds max vfb it saves darker then the rendered image.
See the examples below. maxVFB is the vfb rendered and maxjpg is it saved out to my hard drive
My settings are
gamma/lut 2.2 inside max
color mapping = linear multiply
gamma 2.2
mode color mapping only
not sure if those are the best settings btw.
Any help would be appreciated.
Which 3ds Max version? Make sure the file output gamma is 2.2 as well. In 3ds max 2014, this option is no longer available in the UI, but you can set it from MaxScript like this:fileoutgamma=2.2
Vlado,
3ds max design 2015.
You know whats weird, is if when I got to save the rendered jpg, in the dialoge box, I give it name, save as jpg if I set the gamma manual to 2.2 ( normal its set to Automatic ( Recommended )) then it saves it just the max vfb.
I dont understand whats going on.
See my reply above.
As Vlado already mentioned
use maxscript to set the gamma
Press F11 to bring up the maxscript listener and then paste this in there and press enter:
fileoutgamma=2.2
Or you can paste it in the small text box at the far most bottom left of the max window
Thanks guys. That seemed to work. Is that something I have to do every time I open a scene up?
Just curious why I would need to do that?
once you’ve done it, it will stay like that and you don’t have to set it everytime
If however you open an old file and the gamma was set different with that file, it will ask you to change it or not. Don’t change it and just keep what you set already. If you choose to change as per the old file, it will stay like that untill you change it back again
AD has some really strange defaults on things…
