3dsmax 2016 - Is it usable in production straight out the box ?
Normally, like others, I wait until SP1 for any Max release. How are people finding 2016 ?
I was just wondering the same thing, Im planning on trying it out in the next few days, not in a production sense yet though :wink:
Been fine for me, not really much improvement viewport wise but they don’t seem to have broken too much this time either and my 2015 plugins have worked ok - vray, forest, railclone.
worth the upgrade?[quote=“cooler_inc, post:6, topic:47447, username:cooler_inc”]
[/quote]
well , if you consider their licence policy for 2016 i think its worth it :slight_smile:
I wouldn’t have bothered (for Arch viz) if I had the option not to pay for it - but I’m effectively locked in on subscription so thought I may as well use it.
I am using 2016 for modeling and it’s mostly working fine. One thing that seems broken is object import. On a deadline so I didn’t have the time to figure out all of the nuances but, in general, not having much success importing fbx or obj files into 3dsmax 2016. They import but don’t display. Been using 2015 to import objects from ZBrush.
@Steve: I haven’t run into that problem yet. I know that the new STP importer is fantastic! It’s now a MUST HAVE feature for me. I also do a LOT of importing with FBX and OBJ, along with IGES and SAT files. All seem to be working great.
Do you have a problematic sample file that I could try out on my end to see if we can troubleshoot the problem?
Move to 2016, and working fine in production (we don’t use Backburner). MCG has played a bit on the move, since I had already done a few tools/modifiers (not cloners :)) that helped a lot in some projects.
Don’t you have a big speed problem when you work with groups ?
When i group a bunch of objects (lets say 2-300 teapots) , the viewport is completely lagging or partially freezing for several seconds !
And no problems on 2015 (on a bi xeon workstation with quadro k5000 card…)
Yup, I do have, and reported the problem already, but I do try to stay away from groups :), and always say to all the artists here, avoid groups at all cost. I normally attach everything that should go into a group (that makes sense to attach) or use some helpers (and layers) to parent things that should be in groups.
yeah, that might be ok for some type of work, but i do mostly product viz, and need top copy/paste re-use some produits accross different scenes, so attaching is no way to go.
it’s kind of incredible that nobody never grouped several objects in beta testing and reported this !!
It did work in the beta, this was something that went wrong on the final release. Same for the OSD, it was way faster, and now had some kind of regression.
I too avoid groups at all costs. We do a LOT of product viz as well and I have found that I MUCH prefer working with XRefs over anything else. That way my files are smaller and I have a single source for the products. Bind to a dummy and I can move it around as needed.
yeah well anyway, the product is not usable out-of-the box if basic features do not work any longer :wink:
I’m sure they are working on it. Make sure to use the feedback/user voice so they know this problem persists.
Why do people try and avoid groups?
I had a coworker who hated them and would leave everything ungrouped too but it just made his scenes a nightmare to work in, I never understood the benefit.
Using groups doesn’t make a scene any easier or difficult to work in if the scene is a mess to begin with! :wink:
IME they have created more harm than good. Slow viewport performance, rendering issues (crashing), file corruption, difficult to get all objects moved to a new layer, etc…
I link objects to a main object or helper. I can move everything together and a double click will select the entire hierarchy, if needed. I’m not constantly open/closing groups to access individual objects. Or in some cases have multiple nested groups within groups which is just a pain.
Using layers and simple linking I don’t miss groups. :wink:
I know groups was an old issue, which was resolved many moons ago; maybe people are just holding on to the past.
I have had the opposite evolution in my approach to Groups, in that since I first started out learning Max some 15 years ago I relied heavily on them for everything. While they had issues, they were much easier to use than the alternatives back then. As time went on the layer management and XRef support improved and I gradually moved away from groups because of the lack of flexibility they have. Nowadays I use Layers and XRefs for most scene management, and the only time I really use groups is if I need a bunch of objects to share a common pivot for a while. In that case it’s easier to group them than to handle them as individual objects. Whenever I’m done with whatever I’m doing I almost always ungroup them again. Right now one of my major annoyances is how groups and layers don’t cooperate. For instance, I feel that if you select a group in the layer manager it should select all grouped items, but it doesn’t.
So for me, layers, xrefs and heavier usage of procedural modeling has taken away most of the need for groups.
