Hi Max users,
I’m seriuosly switching to 2018 and I’m facing difficulties with the Select from Scene window.
My problem is this:
with 3dsmax 2016 when I selected some objects and I open the Select from Scene window ( “H” shortcut) I can see the selected objects as highlighted but with 2018 not. I can’t see what are the objects selected. I can’t find an option in the Select from Scene window to enable/disable the highlighting.
Any tips on this?
Ok…I can’t understand any good reason for this… so to understand what I’ve selected is there any other good tools?
Scene explorer through layers could help a little bit on this but when youhave multiply objects inside multiple layers, it’s really not so helpful anymore…
I’m feeling a bit old to say “oh my god!!” but really…what’s the reason for this kind of changes?
I’ve just read now that I should be able to use the old style Select from Scene… I tried it…but how long it will be available this option… I think I know the answer…
I believe there is no reason. It was reprogrammed, and they forgot to take care about this. Or they had problems implementing it in their new system and decided to drop it. I don’t know, but you should complain to Autodesk.
If you make a wish in their system to get this behavior back and post the link here you’d get my vote;)
